How doI change the current mailbox?
- How doI change the current mailbox?
17-07-2015 9:17 PM
My partner and I have got two mail boxes from the same account, but I really can't work out how to change from hers to mine on the webmail page.
Can anyone tell me where the menu is to chance mail boxes?
I've looked and clicked and looked some more, and my eyes are going square! Am I missing the obvious?
Cheers.
Cheers.
Message 1 of 4
(2,222 Views)
3 REPLIES 3
Re: How doI change the current mailbox?
17-07-2015 10:49 PM
You can't change mailboxes when logged into webmail.
You need to logout first then login again to your partner''s mailbox using its username (eg username+partnermbname) and password.
David
Message 2 of 4
(1,576 Views)
18-07-2015 10:02 AM
Got it!!!! Thank you so much, I would never have worked that out. I am just trying to set up a new pc. The frustrating thing was that we both have the same password, so I couldn't understand why we could only open one mail box.
Username+partnername worked. 🙂
Message 3 of 4
(1,576 Views)
18-07-2015 11:41 AM
If you are not familiar with the standard format of Plusnet email addresses you might find artiicle Email addresses explained helps.
David
Message 4 of 4
(1,576 Views)
