How do I rid myself of linkedin?
fotobits
I cannot stop unwanted linkedin emails being accepted into my inbox.
I have both their domain and their email address in my Blocked list.
Surely regardless of the strength of my spam filter, a block list is a block list!
linkedin appear to have an unsubscribe link, but so far as I can see, it leads you to subscribing, not unsubscribing!
How can I rid myself of these poachers of my privacy, trespassers in my Live Mail, thieves of my bandwidth?
Regards.....
9 REPLIES 9
Oldjim
Resting Legend
Fixes: 63
Re: How do I rid myself of linkedin?
Can you post the complete header from one of the emails with your email address munged out
Is this coming to a mailbox which is the catchall. If so it won't work
fotobits
Thank you Old Jim, I haven't a copy right now, however, I'll send a copy as soon as the next one arrives!
None of my mailboxes are "Catchalls"
Regards.....
fotobits
Herewith copy of Linkedin Header.  I confirm that none of my mailboxes are Catchalls :-
Sent: Tuesday, March 20, 2012 1:09 AM
To:
Subject: LinkedIn Network Updates, 3/20/2012
Is this is what is required, Old Jim?
Regards
fotobits
Looking again at the linkedin "sent" domain I see that it's not as I thought earlier.  It appears to be bounce.linkedin.com
I have added this domain to my Blocked List and will see this works.
Rregards.....
James
Hi Fotobits,
Go to https://www.linkedin.com/ and click on your name in the top right, it will ask you to login.
Select email preferences (middle left) and then set the frequency of emails.  You should be able to turn them off from there.
fotobits
Many thanks James, however, the link takes me to the attached.
The only option appears to be to join, which I'm unhappy to do!
Regards......
James
To get those emails, surely you must have an account in the first place?
fotobits
No, James.
I used to be harranged to join.....to add my business to their site....I'm actually retired.....and never responded!  Now they regularly send me confounded details of other subscribers.
I thought I could block them, however, that's not been possible so far and from their email properties it isn't easy to see the actrual source.  Perhaps it changes.....not sure!
Thanks anyway.....
fotobits
I have now added the Linkedin domain to my Norton Blocked List.  That might do it!
Regards.....
