How do I rid myself of linkedin?
- How do I rid myself of linkedin?
15-03-2012 8:14 PM
I have both their domain and their email address in my Blocked list.
Surely regardless of the strength of my spam filter, a block list is a block list!
linkedin appear to have an unsubscribe link, but so far as I can see, it leads you to subscribing, not unsubscribing!
How can I rid myself of these poachers of my privacy, trespassers in my Live Mail, thieves of my bandwidth?
Regards.....
Re: How do I rid myself of linkedin?
15-03-2012 8:44 PM
Is this coming to a mailbox which is the catchall. If so it won't work
15-03-2012 9:14 PM
None of my mailboxes are "Catchalls"
Regards.....
20-03-2012 7:18 AM
Sent: Tuesday, March 20, 2012 1:09 AM
To:
Subject: LinkedIn Network Updates, 3/20/2012
Is this is what is required, Old Jim?
Regards
20-03-2012 7:47 AM
I have added this domain to my Blocked List and will see this works.
Rregards.....
20-03-2012 8:14 AM
Go to https://www.linkedin.com/ and click on your name in the top right, it will ask you to login.
Select email preferences (middle left) and then set the frequency of emails. You should be able to turn them off from there.
20-03-2012 8:51 AM
The only option appears to be to join, which I'm unhappy to do!
Regards......
20-03-2012 9:02 AM
20-03-2012 9:21 AM
I used to be harranged to join.....to add my business to their site....I'm actually retired.....and never responded! Now they regularly send me confounded details of other subscribers.
I thought I could block them, however, that's not been possible so far and from their email properties it isn't easy to see the actrual source. Perhaps it changes.....not sure!
Thanks anyway.....
20-03-2012 9:59 AM
Regards.....
