How can I block a specific email address contacting me...?
- Re: How can I block a specific email address conta...
25-09-2015 6:10 PM
I want to block a specific email address.
It must be simple to do -- but I`ve searched all over and can`t find the answer...
Your help would be much appreciated.
I am a madasafish account user.
Message 1 of 5
(2,785 Views)
4 REPLIES 4
Re: How can I block a specific email address contacting me...?
25-09-2015 6:19 PM
I don't know if it the same for Madasafish but the Plusnet version is via Email Settings then Manage My Mail then Spam and blacklist an address
Message 2 of 5
(2,448 Views)
26-09-2015 12:32 PM
Thanks for the idea....but it doesn't work in Madasafish.
Ridiculous that I cannot simply put an address in somewhere and choose to block it. It should be one of the easiest things to do on a mail program.
I do not want to spend a fortune hanging on a Madasafish helpline...
Any other frustrated Madasafish users out there...?
Message 3 of 5
(2,448 Views)
26-09-2015 12:37 PM
Quote from: artmiller It should be one of the easiest things to do on a mail program.
Setup up an incoming rule in your email client to delete incoming mail that matches the conditions you set. This can also be achieved in Madasfish webmail:
Settings>Mail Filter
Message 4 of 5
(2,448 Views)
27-09-2015 9:14 AM
Huge thanks pwatson.
Finally worked it out.
Most grateful.....................................
Message 5 of 5
(2,448 Views)
