Help setting up android phone
Fixes: 585
Re: Help setting up android phone
Yes, the outgoing server port is wrong.
For SSL security you need port 465 ( note this is depracated )
Port 587 is for STARTTLS
woldsweather
Great! Taht got my phone working.
Still struggling with my wifes.
How do the attached settings look?
I assume as my wifes windos pc with Outlook 2010 is set up for pop3 that the phone will have to be pop3?
Fixes: 585
The incoming server is wrong, it should be mail.plus.net
not necessarily, pop3 or imap defines how the email client handles mail. pop3 downloads email locally to the client (and normally deletes it from the server although it can be configured to leave it) , imap accesses mail from the server. Where multiple clients are accessing the same mailbox , imap is preferable.
woldsweather
Have changed server name but still wont work.
These are the options
IMAP: imap.plus.net port 993 encryption SSL/TLS
POP3: mail.plus.net port 995 encryption SSL/TLS
SMTP: relay.plus.net port 587 encryption STARTTLS
*** For SSL security you need port 465 ***
SMTP: relay.plus.net port 465 encryption SSL
HTH
Fixes: 585
You need to confirm that the credentials (username & password) you are using for your wifes account are correct by trying to login to webmail with the same credentials
woldsweather
Finallyt! I had expected we had same passwords so obviously didn't. Wenmt into manage mailboxes and reset it - all goo - many thanks for all your help.
paul_blitz
Fixes: 4
So many times we tech people assume the worst, and come up with all sorts of things to check, when the reality is that the problem is actually a simple one, that we should have double-checked much sooner!!!
Glad you finally sorted it all out!
Fixes: 251
@paul_blitz
Not so much "we tech people make assumptions" but rather a reasonable acceptance of what we are told or is inferred that a user has the right pairing of username and password.  Such is why a double check that the user can access webmail is so very helpful.
