Help needed to restore archived emails please
gingerpuss52
Hello
Could Plusnet peeps please unarchive my emails?  I have been deleting old emails and large files over the past month or so thinking I was going to be OK.  However, this morning I find all my folders and emails, except the recent inbox items and sent folder have all gone.
It's very important for me to access the folders as I have an ongoing legal issue going on and some very important emails have been saved to folders that I thought were safe.  Maybe I have misunderstood the archiving instructions and checking file sizes etc.
Thanks for your assistance with this problem.
4 REPLIES 4
Fixes: 1,171
Re: Help needed to restore archived emails please
Hi @gingerpuss52 thanks for your post and welcome to our Community Forums.
From what I can see we haven't actually archived your mail yet. I've checked your mailbox and there are definitely emails in there going back to 2013. Can you try going to webmail.plus.net > Settings > Folders > making sure all the folders are ticked? If you then go back to the main Mail page, check each folder.
Let us know how it goes.
gingerpuss52
Hello Gandalf
Many, many sincere thanks for answering my query yesterday.
I have now restored my folders and will deal with them accordingly.  Like a fool, I thought I was dealing with them, after being reminded by Plusnet about the file sizes....you live and learn eh?
Once again, thanks very muchly.
Fixes: 1,171
Thanks for getting back to me @gingerpuss52
Haha no problem at all, the main thing is you've got your mail back now and you know what to do so this shouldn't happen again. Let me know if there are further issues or anything else you'd need help with. Smiley
Fixes: 71
Culling mailbox contents
If you need to clean out your mailbox, may be because it is over quota, then as well as tidying up the inbox, you need to also look at the SENT ITEMS folder and then afterwards clear out the TRASH folder. However some times webmail performance can make this process very tedious, particularly if the delete action (actually a move to the trash folder) fails.
If you primarily want to delete emails, you can mitigate delete performance issues by doing an "immediate" delete (rather than a move to trash for deletion later) by holding down the SHIFT key when pressing the DEL key. This works in both webmail and most PC based email clients. WARNING SHIFT+DEL is not recoverable so be certain absolutely, that you do not need the email before pressing the buttons!
Alternatively, in webmail (Round Cube) Settings -> Server Settings there are some options worth exploring controlling how deletes are performed...
  1. Flag the message for deletion instead of delete
  2. If moving messages to "Deleted Items" fails, permanently delete them
  3. Compact Inbox on logout
Setting these options and using them together will avoid the over heads of moving items to the trash folder when you wish to delete them. They will simply be greyed out and remain in the inbox list. After logging out of webmail, they will then be removed from the mailbox.
Whilst this might be highly proficient, it needs to be used with care, for when they are gone, they are gone. Note also that Plusnet house-keeping clears out the trash folder weekly.
