Having no success in setting up my email
- Having no success in setting up my email
18-01-2020 9:17 AM
i am sure it is my prblem but I cannot get the emails to work. I am using Mozilla Thunderbird under Windows10. I get the message "Sending of the message failed.
An error occurred while sending mail: Outgoing server (SMTP) jctemf.plus.com is unknown. The server may be incorrectly configured. Please verify that your Outgoing server (SMTP) settings are correct and try again." so what am I doing wrong?
Re: Having no success in setting up my email
18-01-2020 9:21 AM - edited 18-01-2020 9:23 AM
@JohnCT1 The outgoing server should be relay.plus.net
Thunderbird has tried to 'guess' your outgoing server settings and unsurprisingly, got it wrong
18-01-2020 10:16 AM
Sad to say that does not work either, however thanks fo the reply.
18-01-2020 11:41 AM
It's definitely relay.plus.net . For info the complete set of settings are here https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/
