Haveing problem with webmail
- Haveing problem with webmail
02-04-2014 10:00 PM
I started with Plusnet fibre on Monday, contacted customer support this morning to set up an email address. I was given the address mail@username.plus.com and I picked a simple password which I would change once I logged into webmail. I have tried all combinations of the email address and I cannot login to webmail, I can login to the username mailbox using the username and password I provided at sign up, Where am I going wrong?
Thanks,
Gerald
Thanks,
Gerald
Message 1 of 3
(778 Views)
2 REPLIES 2
Re: Haveing problem with webmail
03-04-2014 1:40 AM
To log in to an additional mailbox you have to use the format of username+mailbox for the ID part of the login and just to remind you the corresponding password for the mailbox.
The login doesn't accept email addresses for the ID.
That's RPM to you!!
Message 2 of 3
(298 Views)
03-04-2014 10:06 PM
Many thanks,
Gerald
Gerald
Message 3 of 3
(298 Views)
