HELP - advice needed - Can only receive emails from OE on one PC at a time.
- Re: HELP - advice needed - Can only receive emails...
19-10-2010 9:54 AM
Re: HELP - advice needed - Can only receive emails from OE on one PC at a time.
19-10-2010 9:58 AM
Have you tried leaving a copy of your messages on the server? As when you've downloaded messages on one OE they won't be there for the other one if you haven't selected that option.
Jojo
19-10-2010 10:06 AM
19-10-2010 10:06 AM
19-10-2010 11:00 AM
https://portal.plus.net/my.html?3A9gtk3TO7Vnm5tygj41WxGvNgoXUgKqC3f0fFmIgOsmrrsujjYNOoAbUr2%2FgAxC&r...
Email address summary
Email Address Type Destination
@ Mailbox (Default)
arch@ Alias odds@pe.co.uk
c4@ Alias odds@pe.co.uk
cf@ Alias odds@p.co.uk
craft@ Mailbox
19-10-2010 12:28 PM
http://community.plus.net/library/networking/testing-network-faults/#telnet Section 8
22-10-2010 10:10 AM
Thanks for the information. I have tried the fundamental check on the PC not receiving emails and :-
First with AVG scanning incoming emails I got error message 'ERR AVG POP3 Server: Cannot connect to to mail server'
Second with AVG scanning disabled - received message 'Connecting to mail.plus.net' - after a while it timed out and Telnet closed.
What should I do now?
22-10-2010 10:15 AM
22-10-2010 11:00 AM
22-10-2010 12:40 PM
22-10-2010 12:46 PM
It doesnt have a static IP address which is conflicting with one of the other PC's does it ? ( but that would also give problems with internet access as well !! )
25-10-2010 12:36 PM
I have rung Belkin support. I believe there response (it was an Indian voice on a very bad line) was that the ISP should reset the email ports. Does that make sense?
25-10-2010 12:55 PM
Quote I believe there response (it was an Indian voice on a very bad line) was that the ISP should reset the email ports. Does that make sense?
Nope, they're talking rubbish.
