Gmail no longer retrieves my Madasafish emails
Rayt46
Hi I use GMail to retrieve mail from my madasafish account. Today it has stopped retrieving,
I have deleted the account in gmail and tried to add it back in but it would appear that gmail will not see the account.
I can access the webmail using safari so my account and password are correct has the port changed.
Current setting was port 110
Mail server Mail.madasafish.com
Any help will be great.
10 REPLIES 10
Fixes: 235
Re: Gmail no longer retrieves my Madasafish emails
Looks as though there is an issue with the MAAF routing.
Rayt46
I can access the account via web it would appear that gmail times out when trying to connect although login info is correct it does not set up. I am sorry if I am not in the correct forum chat
Fixes: 235
There is still an issue - it has been escalated.
Woldsman
Hi Townman,
Many thanks for your support so far. I know very little about these things and ended up on this forum trying to find out why I can't access my emails. My email is a domain address that operates therough Madasafish and goes back to that time. I can't access Madasafish webmail either to get around it so I have lost function on my main email address. Does the fact that it has been escalated mean there is likely to be a solution shortly or should I ring up Plusnet in the usual way to see if I can get it sorted.  Any help you can give would be much appreciated because as it stands I have no access to my emails many of which may be very important. Is there a way of getting into Madasafish Webmail at present\?
Thanks again.
Fixes: 235
It is a network level issue - the front line staff are unlikely to add anything to this space.
I managed to contact the right people yesterday evening. Changes have been made, but they might need more time to propagate around the internet. Note this is guesswork.
Woldsman
I have just got access to my Madasafish Webmail on webmail.plus.net
.........hopefully it will carry on and the Pop3 servers will follow.
Thanks again
Rayt46
I am assuming it is related to the fact that the domain name has expired but recently renewed (following another thread on this forum) I know its not your issue but its frustrating I am trying to renew Insurance and everything points to that email and nothing is coming in even though I can see the mail via Plusnet
Woldsman
I know what you mean.....I was in a real panic with no email access at all and even though my webmail seems to be working I am very nervous about it stopping again and although I'm very relieved to have it back it is not a long term solution....I need to get back to being able to use my Outlook for the things I need to do through my domain email address.
Thanks once again to Townman!
Rayt46
The problem has been fixed, I have reset the account in Gmail and it is successfully retrieved mail. So the escalation has resolved the issue.
grumble
Does this include 'discussions' with registrars?
