Gmail bouncing my emails with ‘Not Authorized’
- Gmail bouncing my emails with ‘Not Authorized’
22-09-2020 8:20 PM
I’ve been running a personal email server for several years on my PlusNet connection with static IP. I set this up back when PlusNet didn’t support encrypted connections to their own servers and it’s worked pretty flawlessly until today I tried to send an email to a gmail account and it bounced back saying my IP isn’t authorised to send -
https://support.google.com/mail/?p=NotAuthorizedError
Is there a way to get PlusNet to authorise my IP address as per this link?
Re: Gmail bouncing my emails with ‘Not Authorized’
22-09-2020 8:28 PM
22-09-2020 9:00 PM
Yeah maybe. It’s been so long since I set this up I’m a little rusty. If I reconfigure my email clients to send direct to relay.plus.net then I think I’ll need to adjust things like my DKIM/SPF DNS records. Or maybe I can configure postfix on my server to forward via relay.plus.net.
26-11-2020 7:48 PM
I've just had the same issue - running a mail server for years, which now is unable to send to gmail addresses. Is there anyway to sort this out? I have a static IP on my account, and would prefer to keep things running as they have been for many years, and not use the plus net relays.
26-11-2020 8:23 PM
It looks as though Gmail has its own block list similar to the Spamhaus PBL. Where as I used to have to apply for removal from Spamhaus every year, there doesn’t appear to be a similar way to get removed from gmail’s block list. Therefore I had to change my mail server to forward via PlusNet’s relays by adding ‘relayhost = relay.plus.net’ to postfix’s main.cf
Then I had to update my SPF record to add ‘include:madasafish.com‘ so that my emails wouldn’t get rejected for failing SPF.
It all works fine now, although theoretically any PlusNet subscriber could now pass my SPF, but I have configured DKIM to mitigate this.
Hope that helps
