Get Sent messages in Webmail into Outlook
- Get Sent messages in Webmail into Outlook
15-10-2019 7:55 PM
I'm hoping this will be a blindingly obvious fix please!
I'm using Outlook for Office 365, and wonder if there's a way to get messages that I've sent from webmail to be downloaded to Outlook the next time I'm using my home laptop?
Had to send an important email today while I was away from home and for the life of me cannot work out how to get it onto my laptop, and would rather keep a local copy of it than rely on wherever the webmail stores it!
Grateful for any thoughts!
Cheers, j_w
Message 1 of 2
(575 Views)
1 REPLY 1
Re: Get Sent messages in Webmail into Outlook
15-10-2019 8:29 PM
if you connect your account via imap in outlook as well, you can see the sent items and then you should be able to drag and drop the messages.
