Freenetname email still not sending...
SneakyPete
I'm still unable to send emails to different addresses from my mail app on Samsung android.
Webmail works. I have seen there is a fix but no link to where that is.
Can I get a fix please.
2 REPLIES 2
Fixes: 236
Re: Freenetname email still not sending...
What fix?
The only “fix” is to get your connection configuration and credentials correct … if you think they are correct, then use the email server connection diagnostic below.
Fixes: 457
