Font style and size
- Re: Font style and size
Font style and size
13-05-2014 2:11 PM
Have just bought a new lap top and haven't been able to put Mozilla Firefox on to it (which has been the email I have been using on my desk top). Happy to use the PlusNet site even though I don't find it as easy to use. Probably my fault as I find it harder, as I get older, to adapt! I find the font size difficult to read and want to change it. Have looked around PlusNet site but can't find this information.
Thanks in advance for your help.
Message 1 of 3
(1,848 Views)
2 REPLIES 2
13-05-2014 2:52 PM
If you are referring to PlusNet Webmail, then the font size will be controlled by the web browser. I believe, usually, ctrl & plus key (+) will increase the page's font size.
That's RPM to you!!
Message 2 of 3
(1,209 Views)
14-05-2014 11:16 PM
Thanks. I knew someone would help me. Not being very computer literate I only ever know one way of doing anything and that is not necessarily the quickest or best but just me 'bumbling' around until some works.
Message 3 of 3
(1,209 Views)
