Error message "550 5.7.1 Connection refused - blocked by Validity"
StarlightSurfer
Emails to #@tiscali.co.uk addresses (# = name) are returned with the message below.
Please request delisting from Validity so that my emails to tiscali are received by the addressees.
   * #@tiscali.co.uk
Reason: A message that you sent to the following recipient could not be delivered due to a permanent error. ** The remote server ?? responded with: ** #@tiscali.co.uk ??:?? This message was created automatically by mail delivery software on the server .
Reporting-MTA: dns; avasout-peh-002 [212.159.14.18]
Received-From-MTA: dns; mail.enmail.co [91.204.208.8]
Arrival-Date: Sun, 16 Nov 2025 11:07:06 +0000
Final-recipient: rfc822; #@tiscali.co.uk
Diagnostic-Code: smtp; 550 5.7.1 Connection refused - [212.159.14.18] blocked by Validity - https://senderscore.org/blocklist-lookup/ - OXSEU001_102 - https://postmaster-oxseu.vadesecure.com/inbound_error_codes/#_102
Last-attempt-Date: Sun, 16 Nov 2025 11:07:06 +0000
18 REPLIES 18
StarlightSurfer
Re: Error message "550 5.7.1 Connection refused - blocked by Validity"
Also seeing
Connection refused - [84.93.230.250] blocked by Validity
Fixes: 235
@dave / @plusnettony  - in the absence of knowing a more appropriate name ...
avasout-peh-002.plus.net appears to be on four naughty steps concurrently!
mavison
Yet another 550 blocklisted error, this time to a hotmail.com address...
Reporting-MTA: dns; avasout-peh-001 [212.159.14.17]
Arrival-Date: Sat, 29 Nov 2025 18:23:23 +0000
Final-recipient: rfc822; xxxxxxxx@hotmail.com
Diagnostic-Code: smtp; 550 5.7.1 Unfortunately, messages from [212.159.14.17] weren't sent. Please contact your Internet service provider since part of their network is on our block list (S3150). You can also refer your provider to http://mail.live.com/mail/troubleshooting.aspx#errors. [Name=Protocol Filter Agent][AGT=PFA][MxId=11BC5D7A8DF8D60A] [CO1PEPF000044FC.namprd21.prod.outlook.com 2025-11-29T18:23:24.387Z 08DE2EBD47C6A865]
Last-attempt-Date: Sat, 29 Nov 2025 18:23:24 +0000
Note this from a Force9 address which has NOT been migrated (due "from" 8th Dec).
Please can this be unblocked?
plusnettony
Fixes: 46
if these 550's are what I think please check for virii and malware, and change your password as a precaution. I then need to know the email address you are sending FROM so I can check if there is something local that I can fix. PM me the from addresses rather than putting them in the public space. Thanks.
 Tony T
Tykebike
I've been having the same error message when I send to one particular contact and would like to  send the details to you plusnettony but don't know how to pm you. Could you provide me with your address please?
Fixes: 334
@Tykebike To send a PM, right click @plusnettony 's name at the side of his avatar - a new window with a 'send a message' option will open.
plusnettony
Fixes: 46
I can't see anything that I can fix, but I've asked about. I'll PM when I hear back.
 Tony T
Tykebike
Thanks.
I'm having trouble logging into my account this morning and have changed my password but can't connect to webmail.
Waiting for Advisor to call.
plusnettony
Fixes: 46
Where did you change your password (i.e. on which web site ? )
 Tony T
Tykebike
It was on the Plusnet main website. I can log in there but cannot log in to webmail using it.
The advisor thinks that it is due to the migration process and advises me to keep checking by trying to access webmail peridoically throughout the day and then tomorrow morning when the migration should be nearer completion.
Fixes: 235
Which Email brand?
Tykebike
It is Force9
Fixes: 235
@Tykebike
If your email service has been migrated, changing passwords in the PLSUNET user portal is not going to get you anywhere.  You need to manage your email service here - greenby.com
If this is a secondary email address for which you are having issues, then at the time of writing there are issues using the Plusnet webmail web page: login with an email address is not working - use account+mailbox as the user name or use the native Greenby webmail service - webmail.greenby.com
Tykebike
How would I know if my email has been migrated as I've had no indication that it is immenent.
