Error 451 message
- Re: Error 451 message
Error 451 message
31-10-2011 2:12 PM
I am suddenly unable to send emails containing an attachment. The attachment is about 29Mb in size, and right at the end of the upload process I get this message from the email client...
"Error 451:Internal Queuing Error"
The upload seems to progress normally right up to the end. Anyone able to throw any light on this? Is it originating from the PN server?
Edit: Ok.. sent the same attachment using the same email client through a Yahoo smtp server and it worked fine. Looks to me like it's a Plusnet server problem? Anything to do with the recent Spam platform migration?
Message 1 of 5
(2,051 Views)
4 REPLIES 4
31-10-2011 4:56 PM
Hi nozzer,
Hopefully not but it does sounds like it could be. I've passed it on for checking, we'll get back to you as soon as we've any information.
Message 2 of 5
(583 Views)
31-10-2011 5:00 PM
Well the maximum email size hasn't changed during the transition from IronPort > Cloudmark:
Just trying myself to see if I can replicate the problem...
Edit: Sent a 20Mbps test file provided by ThinkBroadband using relay.plus.net and it arrived at the other end in one piece without any errors.
220 avasout07.plus.net smtp relay.plus.net
ehlo avasout
250-avasout07.plus.net hello [84.93.217.40], pleased to meet you
250-HELP
250-AUTH LOGIN PLAIN
250-SIZE 104857600 <---- Maximum size in bytes
250-PIPELINING
250-8BITMIME
250 OK
Message 3 of 5
(583 Views)
01-11-2011 1:22 PM
Managed to replicate the problem with a 50Mb file - we're looking into it...
Edit: Should now be fixed, it was a problem with the config on the Cloudmark boxes.
Message 4 of 5
(583 Views)
01-11-2011 3:03 PM
Thanks Bob. Every one a winner!
Message 5 of 5
(583 Views)
