Entire mailbox contents duplicated via POP3 07/01/2011
- Entire mailbox contents duplicated via POP3 07/01/...
07-01-2011 2:54 PM
just now it has downloaded a complete duplicate set of all emails in my inbox - 375 of them.
i think there's a problem at the PN end ...
Re: Entire mailbox contents duplicated via POP3 07/01/2011
07-01-2011 2:57 PM
07-01-2011 3:00 PM
Quote from: paulBG Matt,
It's doing it again - as I speak my Outlook is downloading duplicates of 799 previously downloaded messages totally over 150Mb. What's happening today?
Cheers
Paul
07-01-2011 3:02 PM
If I look at the webmail.plus.com interface, no duplicates
07-01-2011 3:06 PM
Interested to know whether or not anybody else has just seen this?
07-01-2011 3:24 PM
This is what PN said last time it happened:-
<<I'm afraid this is down to the email issues we had and how the recovery scripts had to be in order to move the mail across to the new platform. Sorry about the hassle, unfortunately there's nothing we can do about the duplication.
There's more detail on how it all happened on our service status archive - the relevant post is http://usertools.plus.net...us/archive/1292858377.htm ; >>
I guess they will update us soon - seems very similar indeed.
Cheers
07-01-2011 3:28 PM
I've asked the support centre to give me a shout if they field any tickets/calls from customers reporting the same problems.
Interestingly, the first two letters of your usernames (TLK) are the same. Your mail is also on the same back-end file systems.
07-01-2011 3:44 PM
Quote from: Bob Interestingly, the first two letters of your usernames (TLK) are the same.
que?
07-01-2011 3:49 PM
Quote from: paulh
que?
Both you and @paulBG have usernames that start with the same two letters. Both of you have mail stored on the same filer. Both of you have had all of your POP3 mail duplicated. Coincidence?
07-01-2011 3:52 PM
07-01-2011 4:49 PM
TLK = Two Letter Key i.e. the first two letters of your username.
07-01-2011 5:26 PM
If you want to leave emails on the server as a backup or so that they are accessible via webmail you should use IMAP not POP3.
07-01-2011 6:16 PM
07-01-2011 7:11 PM
07-01-2011 7:39 PM
Quote from: jelv If you want to leave emails on the server as a backup or so that they are accessible via webmail you should use IMAP not POP3.
Correct me if I'm wrong (& I confess I know very little about IMAP), but I don't think it's quite as clear cut as that.
Presumably the provider of the IMAP server puts a limit on the amount of space allocated to each account. Your total mail store is thus constrained by this limit.
If you have a POP3 account normally configured to leave mail on the server, you can use it as a backup of recent mail & also enable it to be downloaded by a number of separately located clients. Periodically (possibly as you approach your account capacity limit), you can make an additional, secure, off-site archive of your mail & clear down the server, ready to start the cycle over again. Your POP3 client will store mail for far longer than your provider is likely to allow if you have a lot of email traffic.
