Emails won't send
Columbia
Re: Emails won't send
Thanks, I'm glad you've not stopped looking into it.
Let me know how you get on.
Ethel
So far, so good this morning. Fingers crossed
d8smt
Still an issue here. Also doesn't work on Outlook on IoS either.
adamwalker
Fixes: 221
Thanks a lot for the updates, we'll update you the progress from our side of things as soon as we can. - Adam
 Adam Walker
d8smt
For all those still having this problem and using a Microsoft/Outlook client on a mobile (IOS, Android) Operating system - the bad news is this won't be fixed soon. MS have enforced SSL on their clients - they have just confirmed this to me. Which means you can now longer use Outlook, etc. to retrieve your Plusnet emails because PN don't support SSL.
welcome to the 21st Century.
See this thread for more info:
https://community.plus.net/t5/Email/Problems-with-IMAP-access-to-emails/td-p/1516956
Fixes: 1,600
@d8smt have you tried using the mail servers I've advised here?
This should make Outlook connect without using SSL.
d8smt
@Gandalf - yes, these were the servers I was using for Outlook. They stopped working over the weekend.
thx
Dave
Fixes: 1,600
Thanks Dave. Did you add the :143 and :25 at the end of the relevant addresses?
d8smt
@Gandalf indeed. I tried both the 25 & 587 also.
Fixes: 1,600
Did you receive an error message?
Can you send me a PM with a screenshot of the settings you used?
