Emails won't send
Fixes: 1,600
Re: Emails won't send
@PeterSoul are you able to send mail to 1 recipient as opposed to around 70 in one go?
Fixes: 1,600
Glad to hear that @cjags Thumbs_Up
PeterSoul
Apparently yes (sending to myself).  AND I can send the multi-addressee message from webmail.  But still not yet from my PC.  (I have warned them that by the end of this, they will have heard from me several times probably!)
PeterSoul
Curiously, the message-error log lists just the first nine addressees, and then
<- 450 too long without DATA command (closing session)
-> RSET
   An error occurred. - Connection Closed Gracefully.
JimF
I think it would be helpful and potentially mutually beneficial if Plusnet would share what caused these problems and how it was corrected, when this is eventually fully resolved.
Ethel
We too have lost ability to send email from our plusnet account. We get "mail server sent an incorrect greeting. Cannot connect to SMTP server 212.159.9.107 (212.159.9107:587) connect error 10060". We DO seem to be able to send using webmail but can't get a correct username so that doesn't help.
The sending problem has been for 2 days now
SkylineUK_Dup
No change here.  No emails outbound, all stuck in the Outbox.
Knuppel
Fixes: 1,600
We're continuing to investigate this issue.
Apologies for the inconvenience caused and thanks for your patience.
SkylineUK_Dup
All working, from about a minute ago.  I've sent tests, if recipients reply all ok then I'm back in business.
What was the glitch related to?
Cool_smiley
grahamt
Seems OK for me now (latest Windows 10 / Thunderbird 58.2.0, 1-3 recipients).
PeterSoul
And at last it works for me, sending my multi-addressee message!
Fingers crossed...
Fixes: 1,600
Glad to hear it's starting to work again now.
We'll check back here tomorrow.
mikejohnsmith
My outgoing mail is now back working. So far I have only tested it with fairly short test messages, will post back here if i find any issues
Mike
Columbia
I've had this problem since yesterday morning.
I can receive at least some mail.
I'm able occasionally to send mail between my email and gmail addresses, and receive it;
However, most of the time this does not happen, and this morning it is as bad as ever.
I have also been receiving emails I sent to myself several hours after sending them.
Very fed up as a component refresh yesterday did nothing, and this is my work email so crucial.
If there is any news please advise.
Fixes: 1,600
Sorry to hear you're still experiencing problems with sending mail @Columbia
We're still investigating and I've added your account details to the open problem ID.
