Emails not being received
Crick28
I've been receiving emails via my iPhone without problems for a couple of years. Today, for the first time I suddenly got the error message IMAP plus net servers not responding but I haven't touched my iPhone settings. When I compare them with the settings shown on plus net there are no differences. Help! What can I do to fix it?
8 REPLIES 8
Crick28
Re: Emails not being received
After much internet trawling, I think it might be down to the Advanced Settings but I can't see what these should be. Any ideas?Huh
Chris
Legend
Fixes: 169
Make sure that your iPhone isn't trying to force TLS/SSL and retest, hopefully that should sort it out for you.
Crick28
Thank you but the error message still keeps coming up. The advanced settings say: SSL-off, authentication-password, IMAP path prefix -/ and server port-143
Some internet suggestions have been to have the Path Prefix as INBOX but this makes no difference (unless something else needs to change?).
Thanks for your help
bobpullen
Fixes: 316
What server address are you trying to connect to?
Are you able to log into the account using Webmail (preferably from a desktop).
Crick28
Yes no problem at all. The server address is imap.plus.net. If it isn't you'll have to tell me where to look  Smiley
bobpullen
Fixes: 316
That's the correct server address, and the fact that you can use Webmail suggests that there's no problem accessing your account on the IMAP server. If SSL/TLS is disabled and you're using the correct login credentials then I'm at a bit of a loss.
Might be worth deleting/recreating the account on the iPhone.
Crick28
Thanks anyway. I was standing in a railway station when things went awry, so I blame Cross Country Rail entirely!
I'll do as you suggest.
Fixes: 160
I hope you did not!!!  Issues such as this should be verified in different locations, as some mobile data cells can be deficient in their connectivity.
