Emails - how long are they kept on the system
- Re: Emails - how long are they kept on the system
02-06-2017 12:19 PM
just wondering if there is a time limit to how long Plus net keep emails, or do you have to go in manually and delete them?
I used to use pop3 and download them to a laptop but now I'm just using a tablet so using imap which doesn't download them, I just wanted to make sure they will still be on the plusnet server until I delete them.
Cheers,
Mick.
Message 1 of 2
(903 Views)
1 REPLY 1
02-06-2017 1:42 PM
Message 2 of 2
(873 Views)
