Emails Hanging
Emails Hanging
I've had a problem this afternoon when sending emails. The email hangs before leaving my system. i am using TB.
This happens when I reply to a text only email and also when I send a blank to myself.
15 REPLIES 15
Fixes: 107
Re: Emails Hanging
I've been seeing delays on sending emails too...
Re: Emails Hanging
Just to clarify incoming emails are fine. It's just the outgoing ones.
Fixes: 107
Re: Emails Hanging
Yep, incoming fine. Outgoing just seems to pause for a while, but only sometimes...
Fixes: 248
Re: Emails Hanging
Do you experience the same problem when using webmail?
 Harry Beesley
 Plusnet Infrastructure Operations Professional
Re: Emails Hanging
I never use webmail but have just sent a message by webmail and it didn't hang.
Legend
Fixes: 168
Re: Emails Hanging
I don't suppose either of you having the issues has a different email client you can test with?
Re: Emails Hanging
Sorry I don't.
Fixes: 107
Re: Emails Hanging
Yes, I have an Android client. Will try and test on that next time it happens
Re: Emails Hanging
The problem seems to have disappeared. Sending of emails back to normal for me. How about @MisterW?
Fixes: 107
Re: Emails Hanging
Haven't sent any today, will report when I try later
Fixes: 107
Re: Emails Hanging
Well, it does seem to be Thunderbird related. Just tried 2 messages from one of my mailboxes to another, long pause in Thunderbird. Works fine from my Android tablet. Will investigate further...
OK - generated an smtp log , see below
2016-05-11 18:32:27.244607 UTC - -1220098304[b726e180]: SMTP Connecting to: relay.plus.net
2016-05-11 18:32:28.269556 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.269585 UTC - -1220098304[b726e180]: SMTP Response: 220 avasout06 smtp relay.plus.net
2016-05-11 18:32:28.269598 UTC - -1220098304[b726e180]: SMTP entering state: 14
2016-05-11 18:32:28.269615 UTC - -1220098304[b726e180]: SMTP Send: EHLO [192.168.5.65]
2016-05-11 18:32:28.294523 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.294550 UTC - -1220098304[b726e180]: SMTP Response: 250-avasout06 hello [80.229.236.203], pleased to meet you
2016-05-11 18:32:28.294560 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.294565 UTC - -1220098304[b726e180]: SMTP Response: 250-HELP
2016-05-11 18:32:28.294570 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.294574 UTC - -1220098304[b726e180]: SMTP Response: 250-AUTH LOGIN PLAIN
2016-05-11 18:32:28.294579 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.294583 UTC - -1220098304[b726e180]: SMTP Response: 250-SIZE 104857600
2016-05-11 18:32:28.294588 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.294592 UTC - -1220098304[b726e180]: SMTP Response: 250-PIPELINING
2016-05-11 18:32:28.294597 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.294601 UTC - -1220098304[b726e180]: SMTP Response: 250-8BITMIME
2016-05-11 18:32:28.294605 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.294609 UTC - -1220098304[b726e180]: SMTP Response: 250 OK
2016-05-11 18:32:28.294614 UTC - -1220098304[b726e180]: SMTP entering state: 4
2016-05-11 18:32:28.294627 UTC - -1220098304[b726e180]: SMTP entering state: 21
2016-05-11 18:32:28.294637 UTC - -1220098304[b726e180]: SMTP auth: server caps 0x20310, pref 0x40000, failed 0x0, avail caps 0x0
2016-05-11 18:32:28.294642 UTC - -1220098304[b726e180]: (GSSAPI = 0x800, CRAM = 0x2000, NTLM = 0x4000, MSN = 0x8000, PLAIN = 0x200, LOGIN = 0x100, EXTERNAL = 0x400)
2016-05-11 18:32:28.294648 UTC - -1220098304[b726e180]: no auth method remaining
2016-05-11 18:32:28.294652 UTC - -1220098304[b726e180]: SMTP entering state: 3
2016-05-11 18:32:28.295070 UTC - -1220098304[b726e180]: SMTP Send: MAIL FROM:<xxx@xxx.xx.xxx> SIZE=4684
2016-05-11 18:32:28.320279 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.320306 UTC - -1220098304[b726e180]: SMTP Response: 250 <xxx@xxx.xx.xxx> sender ok
2016-05-11 18:32:28.320318 UTC - -1220098304[b726e180]: SMTP entering state: 5
2016-05-11 18:32:28.320331 UTC - -1220098304[b726e180]: SMTP Send: RCPT TO:<<xxx@xxx.xx.xxx>>
2016-05-11 18:32:28.345660 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.345687 UTC - -1220098304[b726e180]: SMTP Response: 250 <xxx@xxx.xx.xxx> recipient ok
2016-05-11 18:32:28.345697 UTC - -1220098304[b726e180]: SMTP entering state: 6
2016-05-11 18:32:28.345702 UTC - -1220098304[b726e180]: SMTP Send: DATA
2016-05-11 18:32:28.372787 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:28.372818 UTC - -1220098304[b726e180]: SMTP Response: 354 enter mail, end with "." on a line by itself
2016-05-11 18:32:28.372829 UTC - -1220098304[b726e180]: SMTP entering state: 7
2016-05-11 18:32:28.373101 UTC - -1220098304[b726e180]: SMTP entering state: 8
2016-05-11 18:32:28.373287 UTC - -1220098304[b726e180]: SMTP Send: .
2016-05-11 18:32:50.401610 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:50.401645 UTC - -1220098304[b726e180]: SMTP Response: 250 t6YT1s00C4PzM7U016YU4K mail accepted for delivery
2016-05-11 18:32:50.401656 UTC - -1220098304[b726e180]: SMTP entering state: 9
2016-05-11 18:32:50.401829 UTC - -1220098304[b726e180]: SMTP Send: QUIT
2016-05-11 18:32:50.401842 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:50.428605 UTC - -1220098304[b726e180]: SMTP entering state: 0
2016-05-11 18:32:50.428636 UTC - -1220098304[b726e180]: SMTP Response: 221 avasout06 smtp closing connection
2016-05-11 18:32:50.428665 UTC - -1220098304[b726e180]: SMTP entering state: 10
2016-05-11 18:32:50.474840 UTC - -1220098304[b726e180]: SMTP entering state: 12
2016-05-11 18:32:50.474938 UTC - -1220098304[b726e180]: SMTP connection error quitting 804b0002, ignoring
as you can see there is a 12 second pause around here
Hopefully someone with a better understanding of the smtp protocol will be able to expalain what's happening ( Bob perhaps? ). Failing that I'll dig a bit deeper...
Re: Emails Hanging
No problems here using TB.
Fixes: 107
Re: Emails Hanging
Mines intermittant, it was fine earlier today...
Looking again at my log above, I'm not convinced its's a TB problem. The delay seems to be between the SEND of the '.' indicating the end of the mail, and the response from PN. There's a delay of 12 seconds!.
As I said , I've not seen a similar problem on my tablet BUT that's using a different smtp server. I'm part the TLS trial so that's using the TLS server. I'm going to try configuring the desktop later, to use the TLS server and see if it makes any difference...
Re: Emails Hanging
I'm getting hanging emails again. it started yesterday. I'm using W7 and Thunderbird.
Anyone else got the problem?
