Email works fine on wifi but not on 4G
egeoffreydavies
Hi all, hope someone can help.
I have an Iphone using Giffgaff PAYG.
My email works perfectly when connected by wifi, but when trying to use 4G away from home, I can receive emails but not send.
I have set up a secondary server to Plusnet and when the phone checks it, everything comes up ok.
When I try sending an email I get the message "Server rejected recipients addresses".
I know that they are correct because they get emails when sent on wifi.
Have tried everything I can think of, any suggestions most welcome.
Geoff
2 REPLIES 2
Fixes: 342
Re: Email works fine on wifi but not on 4G
You will need to set authentication on the outgoing server in order to use it when not on a plusnet connection
See the guide here https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/#what-other-settings-do-i-need
You can leave authentication set permanently, it will still work when on a plusnet connection
egeoffreydavies
Thanks. It's wierd.
Have always used password to authenticate. Rebooted the phone this afternoon and the 4G connection from Giffgaff to Plusnet is now working fine.
Thanks again.
Geoff
