Email problem
- Re: Email problem
Email problem
05-03-2011 8:09 PM
I use Outlook Express 6 as my email client because it's always worked for me, but over the last few days I've had an intermittent problem with incoming mail not being received because the address isn't recognised, or else outgoing is email being bounced back, then the problem seem to clear itself but next day it's back. I've checked my email settings and they're OK and I don't know where else the problem might be.
Anyone got any ideas as to what the problem might be?
Message 1 of 9
(1,823 Views)
8 REPLIES 8
Re: Email problem
05-03-2011 8:13 PM
possibly this http://usertools.plus.net/status/archive/1299084257.htm
Message 2 of 9
(640 Views)
Re: Email problem
05-03-2011 9:27 PM
Thanks PP. I notice the work was done on Thursday, should I still be experiencing problems three days later?
Message 3 of 9
(640 Views)
Re: Email problem
05-03-2011 9:43 PM
You shouldn't
I would raise a ticket
Message 4 of 9
(640 Views)
Re: Email problem
05-03-2011 11:44 PM
I did raise a ticket but they're showing 25hours+ before I get a reply so I thought I'd ask on the forum 'cos I guessed I'd get a quicker response here.
Message 5 of 9
(640 Views)
Re: Email problem
05-03-2011 11:58 PM
Do you get error codes when incoming and outgoing failures occur? If so looking up likely explanations for these might help.
David
Message 6 of 9
(639 Views)
Re: Email problem
06-03-2011 1:51 PM
@spraxyt
The error message is copied below
The following message to
<xxxxxx@xxxxxxxxx.plus.com> was undeliverable.
The reason for the problem:
5.1.0 - Unknown address error 550-'#5.1.0 Address rejected
the error message included the correctly addressed, but supposedly undeliverable message, as an attachment.
No response as yet to my ticket
I had a text message earlier to tell me that an email sent to me this morning had been bounced but it appears to be working OK at the moment.
Message 7 of 9
(639 Views)
Re: Email problem
06-03-2011 8:45 PM
Are there any headers with the returned message which might give a clue?
With this sort of thing being intermittent it has the hall marks of being a timing problem. Anti-Virus taking too long to pass it on and/or the time-out setting in Outlook too short (Server Timeouts setting on Internet E-mail Settings Advanced tab). I have 2 minutes set there.
Do you use Norton? or AVG and ZoneAlarm?
Was the mail sent to you that bounced from a Plusnet user or external?
David
Message 8 of 9
(639 Views)
Re: Email problem
07-03-2011 9:10 PM
@spraxyt
I've reset the timeout at 2 minutes
Iuse AVG antivirus Free version 2011
The bounced message was from an external user
My email seems to be working OK now so the problem whatever it was has gone
Thanks for your time
BC
BC
Message 9 of 9
(639 Views)
