Email access problem
pastie13
I've read similar threads on this and have similar problems - I can't log-in to webmail as I get "ERROR: Connection dropped by IMAP server."
I've created a mailbox but can't seem to send anything to it - I've tried from a variety of addresses and it gets the 'failed delivery' message.
Any ideas please?
Re: Email access problem
Welcome to Plusnet and the Forums Smiley
There appears to be an error on our side so I've forced a rebuild of your mailboxes - this should take between 4 and 8 hours to complete. Once done, everything should be working fine but please let us know if you continue to encounter any further problems.
pastie13
Ok, Ben - many thanks for the quick reply  Smiley
pastie13
I still can't get into webmail  Sad
p.s. I never rule out the possibility that I'm doing something wrong  Grin
OK, let me take a look...
Edit: The rebuild worked, we just then needed to send an email over to create the mailbox fully. I've done this and tested it working OK, you should see the same from your side Smiley
pastie13
Thanks Ben - all seems well!
You rock, old chap  Cheesy
