E-mailing CV.
laptop77
E-mailing CV.
Can anybody help? How do I e-mail my CV?
Fixes: 62
Re: E-mailing CV.
Send it as an attachment in the format requested.
laptop77
Re: E-mailing CV.
Thanks Oldjim.That does not help me one bit.
jim:quote
Fixes: 167
Re: E-mailing CV.
What email client do you use? Webmail, Thunderbird, Outlook etc?
What format is your CV saved in (Word etc)?
If you can give us this info we should be able to help/
 Chris Parr
 Plusnet Staff
laptop77
Re: E-mailing CV.
Thanks for your reply.I will reply about 7.30pm as I have got my elder Brother visiting me at moment.
jim:quote
laptop77
Re: E-mailing CV.
Quote from: Chris
I use Basic Webmail on plusnet,my CV Is saved In Word Starter 2010.
Fixes: 5
Re: E-mailing CV.
Click compose to open a new email
Put the address in the to: box to where it is going to
add a subject in the subject box "my CV" for example
Add the bottom, click "choose".
FInd your CV on your computers file system and click it.
Then click "open" this will close the box.
Then click "add".
You should then be able to click "send" to send the CV to the email address you've put in the to line.
Kelly Dorset
Broadband Service Manager
Fixes: 62
Re: E-mailing CV.
To add to the post above
When you go to Compose you get a screen like this - first picture
Click on Browse - circled - and go to where the file is saved
Click on the file then click on Open - see picture 2
Click on Add - see picture 3
Result - see picture 4
