E-mail settings for i-Phone
FIXED- Subscribe to RSS Feed
- E-mail settings for i-Phone
04-01-2017 6:30 PM
Hi. I've tried several times to set up my Plusnet e-mail account on my new I-Phone. I've used the imap option which seems to be the right one. But when I enter the settings I get a message saying that it's not possible to set up with SSL. So I proceed without SSL. This does set up an account. But only gives me access to messages to the domain for my account - not my specific e-mail address.
Any help would be appreciated.
Fixed! Go to the fix.
04-01-2017 9:38 PM
Getting the SSL/TLS warning is normal since connection using this protocol is not supported. Normally the warning occurs twice, once for the incoming IMAP server and once for the outgoing SMTP server. Both have to be accepted to proceed and set up the account.
If your default email address is set up as (say) first1@accountname.plus.com you would collect emails by logging into the server with username = accountname and password as the account password.
If you have an additional mailbox such as second1@accountname.plus.com you collect emails for this by logging in with username = accountname+second1 and password as set in Manage My Mail for the second1 mailbox.
Does this explanation cover what's causing your access problem?
Re: E-mail settings for i-Phone
05-01-2017 1:39 PM
David, it was a simple solution to something I'd been struggling with for days.
Regards,
Mike
