E-mail layout
NickyOver
E-mail layout
Can I change the layout of a reply on the Plusnet webmail page so that the reply I'm typing comes before the quoted text I received? And is there any auto-correct feature? Thanks for any help!
3 REPLIES 3
198kHz
Fixes: 41
Re: E-mail layout
Select "Settings".
Then "Composing Messages".
In "Main Options" look for "When replying" and select "Start new message above original".
I'm not aware of any auto-correct feature, but there is a "Check spelling before sending" option in the "Composing Messages" section.
Murphy was an optimist
BT technician (Retired)
NickyOver
Re: E-mail layout
That's great, thanks - all sorted. I hadn't spotted the other "settings" button at the top there.
198kHz
Fixes: 41
Re: E-mail layout
Great - thanks for update.  👍
