E-mail images
- Re: E-mail images
E-mail images
18-11-2011 9:26 PM
I have just migrated from Madasafish to Plusnet and I am having problems with e-mail
I cant get images displayed on email when I open them.... its just text. Plusnet have changed my display to Javascript, but its just the same.
My old totalise, e-mail displayed them perfectly!!
What is my problem
What is my problem
Message 1 of 8
(1,754 Views)
7 REPLIES 7
Re: E-mail images
18-11-2011 9:45 PM
Are you using webmail and if not which email client are you using
If webmail then you might try (from within the webmail window after logging into your mailbox) Options, Display Preferences and select Show HTML version by default
Message 2 of 8
(736 Views)
Re: E-mail images
19-11-2011 12:51 PM
I am using webmail and IE8. but its the same with any browser, ie google or Opera
Originally my display options were set to HTML but plusnet changed them to Javascript. but it made no difference.
I'm not sure it isn't a security problem.
When the page doesn't display images there is an attatchment which I can open and them click on ' View unsafe images' or similar and Lo and Behold the e-mail now diisplays correctly
Hope this helps
Hope this helps
Message 3 of 8
(736 Views)
Re: E-mail images
19-11-2011 3:37 PM
Have you ticked
Display Attached Images with Message:
Message 4 of 8
(736 Views)
Re: E-mail images
21-11-2011 11:34 AM
yes definitely. It should work, but it doesn't.
It's now been refered to the Mail Management team.
Message 5 of 8
(736 Views)
Re: E-mail images
21-11-2011 1:16 PM
The blocking of inline images is intended behaviour in SquirrelMail. I've replied to your support ticket though suggesting a possible workaround.
Message 6 of 8
(736 Views)
Re: E-mail images
12-01-2012 4:19 PM
Hi, any chance of sharing the 'work around' I have the same problem
Message 7 of 8
(736 Views)
Re: E-mail images
12-01-2012 4:27 PM
https://betawebmail.plus.net/
Message 8 of 8
(736 Views)
