Delays again
SteveA
Delays again
If its not emails being delivered to spamcop its incoming emails being delayed for no reason.
[tt]Received: from relay.ptn-ipout02.plus.net (relay.ptn-ipout02.plus.net [212.159.7.36])
(using TLSv1 with cipher RC4-SHA (128/128 bits))
(No client certificate requested)
by xxx.xxx.uk (Postfix) with ESMTPS id 398F4A4A15D
for <xxx@xx.xxx.com>; Tue, 22 Nov 2011 19:11:54 +0000 (GMT)
Received: from mail.just-the-name.co.uk ([213.162.97.161])
  by relay.ptn-ipout02.plus.net with ESMTP; 22 Nov 2011 19:11:53 +0000
Received: from mta20153.pur3.net (mta20153.pur3.net [94.236.20.153])
by mail.just-the-name.co.uk (Postfix) with ESMTP id 58823214E27
for <xxx@xxx.xxx.uk>; Tue, 22 Nov 2011 17:55:08 +0000 (GMT)[/tt]
13 REPLIES 13
SteveA
Re: Delays again
It looks like its a bottleneck between JTN and PN  again as emails sent to PN email address arrive immediately.
bobpullen
Fixes: 314
Re: Delays again
That mail is being smarthosted via the Ironport boxes.
We switched the smarthosting to point at Cloudmark back on the 27th October but had to revert the change. A similar thing happened yesterday. We've just attempted the change again though so the mail should be going via Cloudmark rather than Ironport. Keep an eye on it Steve and let me know if the problem persists under this arrangement...
jwhite
Re: Delays again
I've been following SteveA's threads as I have the same problem.  My last mail message received via JTN was sent at 12:28 and arrived at 14:34 (GMT) today.  Other messages known to have been sent in the last hour have not yet arrived.  This is the worst I have seen it.
SteveA
Re: Delays again
Still having problems:
[tt]Received: from avasout05.plus.net (avasout05.plus.net [84.93.230.250])
by xxx.xxx.uk (Postfix) with ESMTP id E7186A4AB44
for <xxxx@xxxxxx.plus.com>; Wed, 23 Nov 2011 18:35:32 +0000 (GMT)
by avasout05 with smtp
id 0ibX1i0073UurnZ01ibYks; Wed, 23 Nov 2011 18:35:32 +0000
X-CM-Score: 0.00
X-CNFS-Analysis: v=2.0 cv=MKHiabll c=1 sm=1 a=ZpolO4lGDM8EQN6SIGXYVw==:17
a=BLceEmwcHowA:10 a=m_t_12sTAAAA:8 a=vnREMb7VAAAA:8 a=Y06chMaLAAAA:8
a=o1OHuDzbAAAA:8 a=EnKFImxacIjvjALGaMkA:9 a=CjuIK1q_8ugA:10 a=sJPsuTjNJwcA:10
a=-Nj4MwkA5LgVwGTJJGoA:9 a=ycyjIHOEtmU97Xs8UP4A:7
a=ub1ZW+Sf4HKBpzZNKCdTEQ==:117
Received: from gloucestershire.gov.uk (glosnet.gloscc.gov.uk [195.188.220.253])
by mail.just-the-name.co.uk (Postfix) with ESMTP id D59AA194232
for <xxxxx@xxxx.org.uk>; Wed, 23 Nov 2011 16:32:37 +0000 (GMT)
Received: from Unknown [142.42.4.34] by mailhost.gloucestershire.gov.uk - Websense Email Security (7.0.0); Wed, 23 Nov 2011 16:32:37 +0000
Received: from svrshir167.gloscc.gov.uk ([10.90.1.22]) by
svrshir169.gloscc.gov.uk ([10.90.1.27]) with mapi; Wed, 23 Nov 2011 16:32:36[/tt]
jwhite
Re: Delays again
You're doing better than me.  Delay now approaching 4 hours.
SteveA
Re: Delays again
Its getting worse:
[tt]
Received: from avasout04.plus.net (avasout04.plus.net [212.159.14.19])
by xx.xxx.uk (Postfix) with ESMTP id EBBA2A4A15D
for <xxxxx@xxxxxx.plus.com>; Wed, 23 Nov 2011 20:23:15 +0000 (GMT)
by avasout04 with smtp
id 0kPE1i0033UurnZ01kPFSj; Wed, 23 Nov 2011 20:23:15 +0000
X-CM-Score: 0.00
X-CNFS-Analysis: v=2.0 cv=KctQQHkD c=1 sm=1 a=efio57i/i5XOAZi986bl8Q==:17
a=cRKPKPvaeiMA:10 a=Hlablx-7v3wA:10 a=Dm3IIXfhAwIA:10 a=rty9J_G-23cA:10
a=m-USZ75diNEA:10 a=IkcTkHD0fZMA:10 a=UznQEXhpAAAA:8 a=zs08ip0SAAAA:8
a=9QUNp-BwAAAA:8 a=XHIS2Z9OAAAA:8 a=-h0B6gQ0NQwCyxIxGc8A:9
a=kDyy1iuyQRDBnCLUwE0A:7 a=QEXdDO2ut3YA:10 a=PNv-TKrp59MA:10
a=L4mBkjDbHRYA:10 a=Ce3eXqMIVoEA:10 a=b6oLwRwpUs0A:10
Received: from mail052.priorityoneemail.com (mail052.priorityoneemail.com [69.10.237.52])
by mail.just-the-name.co.uk (Postfix) with ESMTP id 4BD6F194257
for <xxxx@xxx.xxx.uk>; Wed, 23 Nov 2011 16:33:22 +0000 (GMT)[/tt]
jwhite
Re: Delays again
Delay still about 6 minutes at 8am this morning.  On past days since this started, it's always recovered from the previous day by this time.  Whatever was changed on 22nd, I'm afraid it's made things worse, not better.
bobpullen
Fixes: 314
Re: Delays again
Presuming this is still happening guys?
jwhite
Re: Delays again
OK this morning.  Test message sent a few minutes ago had just a second or two delay.  Problems have been mostly in afternoon-evening, presumably when load increases, so will check again later.
bobpullen
Fixes: 314
Re: Delays again
Thanks, if we get any more reports then I'll open an internal problem and have somebody take a look.
jwhite
Re: Delays again
OK Monday at 5:30 pm - just a couple of seconds delay - so maybe problem is fixed.
SteveA
Re: Delays again
Looks like it might have cleared up - stuff seems to be coming in OK now
bobpullen
Fixes: 314
Re: Delays again
Thanks Steve, keep an eye on it and shout up if the problem resurfaces.
