Contacts.
tedsedg
Contacts.
Can i save an incoming e mail address to a contact list without having to type it in. Thanks. Ted.
7 REPLIES 7
hulls
Re: Contacts.
Using which piece of software?
Strat
Fixes: 565
Re: Contacts.
In Outlook it's a 'Right Click the address and select Add to Contacts' but as Hulls implies we don't know what mail client you are using...if any.
tedsedg
Contacts
Sorry Strat & Hulls, Not sure what you mean by mail client & software. My laptop uses Windows Vista & i am on Plusnet email. Ted.
HPsauce
Re: Contacts
Crazy post out of the blue?
What program do you run to get to your email and receive/send emails? That is a "mail client"
e.g. Windows Mail, Thunderbird, Internet Explorer etc. etc.
tedsedg
Re: Contacts
Hi HP sauce, Strat & Hulls. I think i am using Internet explorer. Thanks Ted.
Oldjim
Resting Legend
Fixes: 63
Re: Contacts.
Topics merged as they seem to be the same
ChrisL
Re: Contacts.
Hi Ted
I assume you're using Outlook Express as your email client. In which case, when you're looking in your 'Inbox', just right-click the mail you're interested in and then select the menu item 'Add sender to Address Book'.  Simples!
Hope this helps.
Chris
