Cant send email when using webmail
keppy2008
HI
When trying to send mail whilst using webmail  (plusnet betamail    )  about 80 - 90 % of the attempts i get an error message saying SMPT  error  cant connect to server.
Frustratingly i copy the message  and paste into the old basic email..... the mail instantly transmits.
So do i have incorrect settings ?  Or are the servers unreliable ?
Should i play safe and forget betamail and revert to basic mail ?
Happy new year .
Keppy
4 REPLIES 4
spraxyt
Resting Legend
Fixes: 75
Re: Cant send email when using webmail
You should not be using beta webmail now. Roundcube became the standard webmail offering last April and is accessed at https://webmail.plus.net/. Is it this one or its old beta implementation that fails for you?
I've just tried sending from webmail (Roundcube) and it worked OK - admittedly a sample of one.
David
keppy2008
HI
Hopefully you have pinpointed the problem.... have been using https://betawebmail.plus.net/ ;     , why does it remain available  ?
Have just tried https://webmail.plus.net/ ;   and first attempt success.
Fingers crossed  this post  now closed .
Happy and Healthy  New Year to all  forum readers.
keppy
drj
This is exactly the same problem that I've been suffering with for months - refer my last posting at Unable to send emails
I will now reset my shortcut to see if the problem goes away.
Anotherone
Champion
Fixes: 21
I've commented on the other thread.
