Cannot see folders in Inbox using webmail
- Cannot see folders in Inbox using webmail
18-09-2010 5:21 PM
I can log into to webmail and see in the left hand pane that I have 92 new messages in my inbox but when I click on Inbox, it doesn't show the messages.
I am away from home and would really like to access these so any help would be much appreciated.
I have been successful in using webmail on this laptop at home in the past.
Thank you,
Vicky
Thank you,
Vicky
Message 1 of 6
(1,701 Views)
5 REPLIES 5
Re: Cannot see folders in Inbox using webmail
18-09-2010 5:25 PM
I should say that I can click on Drafts, Sent and Trash and they come up as normal (although all 3 are empty!)
Message 2 of 6
(759 Views)
18-09-2010 5:44 PM
At the top click Folders, then subscribe to them!
Message 3 of 6
(759 Views)
18-09-2010 5:48 PM
Thank you for your reply.
I tried that but it says that "No folders were found to subscribe to!"
Message 4 of 6
(759 Views)
19-09-2010 4:17 PM
Presumably you have been able to see the folders at some time in the past?
Message 5 of 6
(759 Views)
19-09-2010 9:19 PM
Quote from: ls11 I can log into to webmail and see in the left hand pane that I have 92 new messages in my inbox but when I click on Inbox, it doesn't show the messages.
Hi Vicky, what does it show? An error message? A blank white screen? An empty inbox?
You could try using another web browser to see if it's anything to do with that i.e. Firefox instead of Internet Explorer.
If that doesn't work and you still really need to get to your messages then you could try using Mail2Web .
You need to login using:
Your email address: <your mailbox username>@mail.plus.net
password: <your mailbox password>
That should allow you to view any messages that you have on the server.
Message 6 of 6
(759 Views)
