Can receive, but not send POP3 messages with my freenetname.co.uk account
Fixes: 236
Re: Can receive, but not send POP3 messages with my freenetname.co.uk account
The guidance “Note if you use one of the other brand email services, use the appropriate SMTP server name for that brand” covers that point.
Fixes: 124
It does say that, but in my view it could be clearer, perhaps state the options before describing the process, it was here
The following may be clearer
Launch a windows command line window (DOS window) - press windows-key+R - type CMD into the run box - click OK
Note: In example below it assumes you are using a plusnet email address, if you use one of the other brand email services supported by plusnet, use the appropriate SMTP server name for that brand. example for Free-Online you would use telnet relay.free-online.net.
