Can I delete the 'postmaster' alias and then set it up as a redirect without any bad consequences?
FIXEDTopic Options
- Re: Can I delete the 'postmaster' alias and then s...
08-09-2019 11:47 PM
I would like to delete the current 'postmaster' alias and enter a new redirect 'postmaster'.
1. Is it possible?
2. Will it have any undesirable consequences?
Fixed! Go to the fix.
Message 1 of 3
(586 Views)
2 REPLIES 2
09-09-2019 1:26 PM
Hi @tfc2,
You can delete the postmaster alias and set up a postmaster redirect. There is a possibility during the time it takes to update and build any emails sent could bounce, but after this it should all be fine.
Message 2 of 3
(545 Views)
Re: Can I delete the 'postmaster' alias and then set it up as a redirect without any bad conseque...
09-09-2019 3:18 PM
Thanks Joe!
Message 3 of 3
(534 Views)
