Bounceback email from fireflyuk.net
colourqueen
I'm trying to email a friend on a fireflyuk.net email address and I am getting bounce-backs with the following error code
Server error: '452 4.1.1 ... temporary failure'
He has looked and there is nothing on his server-side delivery log so it is not getting as far as firefly.
Is there anything I can do or does anyone know where the problem is?
5 REPLIES 5
Browni
Aspiring Hero
Fixes: 60
Re: Bounceback email from fireflyuk.net
Error 452 can indicate a full mailbox.
If that is the case there's not a lot you can do until your friend frees up some space to accept incoming email.
colourqueen
Thanks for the suggestion but I know for sure it is not that as they are receiving emails from other people and they have plenty of mailbox space.
adrianscotter
Almost certainly a DNS error...  without the NDR, it's hard to tell Smiley
Live long and prosper!
bobpullen
Fixes: 307
I obviously don't know the actual address you're trying to send to, but I can send email directly to postmaster@fireflyuk.net and it's accepted:
~$ telnet spamshield.firefly-cloud.com 25
Trying 52.211.27.78...
Connected to spamshield.firefly-cloud.com.
Escape character is '^]'.
220 spamshield.firefly-cloud.com ESMTP Postfix
ehlo plus.net
250-spamshield.firefly-cloud.com
250-PIPELINING
250-SIZE
250-ETRN
250-ENHANCEDSTATUSCODES
250-8BITMIME
250 DSN
mail from:<support@plus.net>
250 2.1.0 Ok
rcpt to:<postmaster@fireflyuk.net>
250 2.1.5 Ok
data
354 End data with <CR><LF>.<CR><LF>
subject: test
this is a test, please ignore
250 2.0.0 Ok: queued as 732106C480
quit
221 2.0.0 Bye
Connection closed by foreign host.
That suggests there's nothing wrong with the receiving server, assuming the problem isn't intermittent.
Like @Browni says, could be an issue specific to the particular mailbox you're trying to send to.
Or a communication problem between our email servers and fireflyuk.net's.
colourqueen
Thanks for checking. The issue seems to have cleared now. I managed to send an email mid week. It definately would not work all weekend.
