Best way to send 100 photos?
catgut
newbie asking for advice how best  to electronically send 100 photos to one other family member.(apart from burning a disc)
many thanks
9 REPLIES 9
bobpullen
Fixes: 307
Re: Best way to send 100 photos?
Depending on the file size of the photos, you might get away with uploading them to a free Flickr account? I'd suggest against using email.
itsme
snozboz
Or you could both set up a free Dropbox account: https://www.dropbox.com/ to share files incl. photos between you.
pierre_pierre
the free flicker has a limit to how many you can up load a day, so it might take you a few days to upload the 100, not sure what the limit is as I have a paid account with no limit
bobpullen
Fixes: 307
I was aware there was a 300MB monthly limit but didn't know about a daily limit? You may well be right though seeing as I don't use the service all that often.
pierre_pierre
I could be wrong but 100 photos could be over 300 M, but not likely
catgut
many thanks for your suggestions
seanbranagh
You could use some sort of free ftp space, zip the photos up and send a link or credentials.
I do this often. At the weekend I travelled to a family event at the other end of the country, when I got home I uploaded all of the uncompressed photos from my camera in a zip file (200Mb) and sent the link to other family members.
My family members also have credentials so they can do the same.
I have my own servers but I am sure there would be ftp space available free on a Google search.
tomm
I don't usually like plugging Microsoft wares, they can afford their own advertising, but Skydrive gives you 25GB for free. Picassa (which I do use and like), 1GB for free.
You can do all the usual sharing stuff and send email linkies to photo's etc.
http://explore.live.com/windows-live-skydrive-photos-videos
