Authenticated SMTP connection fails from OSX 10.10 Yosemite
- Re: Secure SMTP connection fails from OSX 10.10 Yo...
16-11-2014 2:48 PM
The smtp server is showing up as Offline when the credentials are completed.
I have a Mac Mini at my home address. If I "allow insecure authentication" I can send mail - but I don't want that.
I have no problem sending mail using Thunderbird from a Win7 machine using the same credentials from the same connection.
Re: Secure SMTP connection fails from OSX 10.10 Yosemite
16-11-2014 2:50 PM
16-11-2014 3:12 PM
I also tried my primary plusnet account with no mailbox - no difference either
16-11-2014 3:24 PM
Re: Authenticated SMTP connection fails from OSX 10.10 Yosemite
16-11-2014 7:16 PM
I just wanted to replicate the settings I use with Thunderbird \ Win7.
16-11-2014 10:35 PM
17-11-2014 2:14 PM
However for the SMTP server there is just a list of authentication options to choose from : None, TLS, GSSAPI, NTLM, MD5, Password.
When "None" is selected I can send mail, when "Password" is selected and I complete my credentials, mail will not send.
17-11-2014 3:25 PM
17-11-2014 4:04 PM
17-11-2014 4:11 PM
Quote from: spraxyt Since you are experiencing "SMTP server showing up as offline" does one of the fixes mentioned by OSXDaily here help?
Thanks for the link, I had already found this advice and I have now solved the problem.
It seems the configuration dialogue boxes in Mac Mail do not include the option for allowing unsecured authentication to SMTP servers.
The option is however included in the plist config text files for the Mail app. So a bit of text editing solved the problem.
19-11-2014 4:52 PM
Quote from: u123072 It seems the configuration dialogue boxes in Mac Mail do not include the option for allowing unsecured authentication to SMTP servers.
OSX 10.10.1 has just been release and lo and behold the configuration dialogs now have a check box for this.
19-11-2014 5:19 PM
