Are there problems with Email? Can't login to webmail or connect to POP or IMAP
- Are there problems with Email? Can't login to web...
18-02-2014 9:26 PM
I'm running Outlook 2003 and unable to connect to either mail.force9.net or imap.force9.net. Also can't login to webmail - just returns me to the login screen with empty password.
Nothing on Service Status.
Oh, outgoing works fine (relay.force9.net)
A tortoise? What's that?
You know what a turtle is? Same thing.
Message 1 of 8
(1,737 Views)
7 REPLIES 7
Re: Are there problems with Email? Can't login to webmail or connect to POP or IMAP
18-02-2014 9:30 PM
I'm seeing some issues too. So it's not just you (oh and I'm on free-online).
That's RPM to you!!
Message 2 of 8
(1,176 Views)
18-02-2014 9:31 PM
yup definitely down.
Message 3 of 8
(1,176 Views)
18-02-2014 9:33 PM
Same problem here. Can go online, can send e mail but cannot receive. Connection Doctor (Mac Mail) just shows the POP thingy spinning and then a message saying the port 110 timed out. Tried to use the online help and it more or less told me to sort it myself. Fine if you're a techie but not so fine if you're not. Nothing on the service status regarding e mail problems.
Message 4 of 8
(1,176 Views)
18-02-2014 9:35 PM
Suddenly sprung back into action - receiving mail now. Lets hope it lasts and that next time Plusnet update the service status so at least we know they are aware of a problem.
Message 5 of 8
(1,176 Views)
18-02-2014 9:37 PM
Ah yes. Bingo!
Message 6 of 8
(1,176 Views)
18-02-2014 9:38 PM
OK now.
Message 7 of 8
(1,176 Views)
19-02-2014 11:28 AM
What now???? Suddenly got a load of old e mails coming into my inbox some of which are several weeks old and I deleted from the server. What is happening with Plusnet e mail? No mention of problems but clearly there is something going wrong. Fess up guys, and fix it!
Message 8 of 8
(1,176 Views)
