Archived mailbox? Request for it to be unarchived here! (Part 2)
- Re: Archived mailbox? Request for it to be unarchi...
Re: Archived mailbox? Request for it to be unarchived here! (Part 2)
04-07-2025 10:02 PM - edited 04-07-2025 10:10 PM
07-07-2025 8:42 AM
Please can you tell me whether my emails have been archived again?
Over the weekend I’ve deleted extensively, and now all of a sudden, all but the last two weeks have disappeared.
08-07-2025 10:14 AM
@dwp99 Thank you for reaching out, I'm sorry to hear your mail box has been archived again. I have re-raised a task for this to be unarchived, however, the inbox is over capacity and it will keep on being archived if emails are not deleted, can I also advise that when deleting emails, in order to get the space free, they have to be deleted from the "deleted" inbox as well.
@stevel59 I tried calling you noting no answer and only the option to leave a voicemail, I hope you are well. At your earliest convenience, please can you DM us the best contact number and a window of time suitable to call you back so that we can discuss his further with you.
Looking forward to hearing from you soon.
11-07-2025 6:06 PM
Looks like my inbox has been archived again, can someone please restore the one beginning in esa ?
Once again, I only discovered the tickets asking me to have a clear up after logging in here because my emails have vanished! Is there some way I can make sure they appear somewhere I can read before it's too late?
Cheers,
Joe.
13-07-2025 10:30 AM
14-07-2025 12:09 PM
Hi, please can you restore my archived emails so I can sort through them.
Mailboxes are on *@thep******y.plus.com
Maildir-sarah and Remaining Mail
Sarah
14-07-2025 1:32 PM
Hi, thanks for looking into this for me, unfortunately that link doesn't work for me, I get the following error message:
Help Assistant
Sorry, but something isn't right
There was a problem with your question. Please check and try againThere was an error
We were unable to access your ticket information.
14-07-2025 2:06 PM
@JoeTWO Could be an error with the ticket number, log into your member centre account and use the link below, it should find any questions/tickets on your account.
14-07-2025 4:33 PM - edited 14-07-2025 4:37 PM
@RealAleMadrid wrote:
... use the link below, it should find any questions/tickets on your account.
https://www.plus.net/member-centre/login?p=search
@RealAleMadrid I tried that (always tend to check links before thanking a post) and - curiously - it wouldn't work. Logged in, lots of other info displayed but no sign of tickets.
However *this* did:
https://portal.plus.net/wizard/?p=search
... which redirects to
... which when logged in redirects to
https://www.plus.net/wizard/?p=search
... whereas the *primary* link being https://www.plus.net/member-centre/login?p=search (as in your post above)
... just goes to https://www.plus.net/member-centre/home?login=true (post login).
... Which causes me to think that the "portal", "member centre", call it what you will, (deliberately) displays a standard-type URL at login stage *regardless* of by-what-means the login page was reached, but once the login activates, the intended destination becomes visible again in the URL.
That's my guess, anyway.
14-07-2025 11:36 PM
That link didn't do anything for me either, unfortunately ![]()
The original link that was sent the first time my email was archived does take me to the tickets warning me about being archived this time, but says I have no open tickets!
on
15-07-2025
4:17 PM
- last edited on
16-07-2025
11:04 AM
by
@JoeTWO Hi!
I can see why that happened. Sorted and
I have requested for your mail box to be unarchived now, this should be done within the next 5 working days.
I could not see an email address beginning with what you mentioned though.
Only your default mail box.
Do you have a separate mail only account or anything like that?
You can always private message me if you have a username or the full email address I should be able to search using that.
I've also updated your account with a new ticket regarding the raised task for email unarchive.
You should now be able to reply on there, since it is an open ticket.
https://www.plus.net/wizard/?p=view_question&id=249071759
Thanks,
Lex
Moderators Note: Link requested
15-07-2025 10:10 PM
Please can I have my emails unarchived
16-07-2025 8:20 PM
Just wondering whether my request is still in hand, as I would like to do some extensive deleting this weekend.
17-07-2025 1:54 PM
17-07-2025 10:49 PM
Thank you, Joe. Alas, no, no sign of anything yet. Please do chase this up for me.
Many thanks
