Archived mailbox? Request for it to be unarchived here! (Part 2)
willcutforth
Fixes: 113
Re: Archived mailbox? Request for it to be unarchived here! (Part 2)
@spitfire1500 I do apologise it seems like the account had the wrong username but I have found it through the email address. I am raising this for you now.
 Will Cutforth
sn5775
Would it be possible, please, to request un-archiving of my mailbox, the address begins with ste............. .plus.com.
I will then delete some messages.
Thank you in advance.
Kind regards,
Steve.
willcutforth
Fixes: 113
I have popped through a request now @sn5775 give it a few hours and it should be done Smiley
 Will Cutforth
PeteK
Can you please restore the archived email for my account beginning with M so I can move the emails elsewhere.
adamwalker
Fixes: 223
Hi @PeteK, just submitted that request for you so it should get picked up within the next 5 working days.
 Adam Walker
Davewill
Hi, can you unarchive my emails please.
adamwalker
Fixes: 223
Hi @Davewill
I've just sent you a PM to check some details with you, please drop me a reply to that when you can.
Adam
 Adam Walker
arkay
Please can I have my emails unarchived.
At the moment I'm doing some things that are generating some quite big emails and it's extra difficult to keep the total size down.
Especially since there doesn't seem to be any way of finding out how miuch space is being used.  The method that was given in some of the emails always showed zero for me.  If there is a proper way please can someone explain.
Regards,
Richard.
SammyM
Fixes: 101
Hiya @arkay
Ta for getting in touch and sorry your emails have been archived.
I have requested them to be restored and this will be done in the next 5 working days. It is usually faster than that.
Are you accessing the webmail or using a client? if So which client?
 Sammy M - Sheffield Team
arkay
Thank you, the messages are back.
I'm using Thunderbird for normal use.  I don't think that can tell me about usage on the server.
To get folder size I'm using webmail.  It's always been slow to login (even very slow, or so slow it times out after waiting an age) though I've just managed to log-in successfully.  When I've tried it before I've generally had it tell me the size was zero, though I've just done it again and it has given me a number.
Regards,
Richard.
SammyM
Fixes: 101
Is that across multiple devices?
Have you thought of changing the settings so that thunder bird will remove them from the webmail mail box and download them to your device.
arkay
Yes.  Laptop and phone.  Also webmail possible when it works (which it did today - maybe the long-standing problem is resolved).
I am deliberately using IMAP so it doesn't do this.  I used, years ago, to have Outlook Express which did only POP which did.  Certainly now I don't want that.
Fixes: 236
Webmail - check that the sort sequence is NONE.
twillcomp1
Please could you unarchive one of the mailboxes on my account. Mailbox starts ja and is archived about 20/11/23 as not accessed recently enough. cheers Twillcomp.
MatthewWheeler
Fixes: 503
Hi @twillcomp1
Can you drop me a PM with a screenshot of the e-mail advising this so we can raise it to the right team
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
