Anyone else having problems receiving emails?
Annie
Is anyone else having problems receiving emails via POP3? I can get them on IMAP and on webmail but am unable to download them to my PC via Thunderbird with POP3. I'm getting 'Connection to server mail.plus.net timed out' errors.
Annie
6 REPLIES 6
Annie
Re: Anyone else having problems receiving emails?
Following on from my previous post, I recently changed the settings in some of my Plusnet accounts to use STARTTLS using the settings at https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/
It seems that this is where the issue occurs. If I change the port back to 110 and no security then I can download mail. What might I be doing wrong to not be able to use STARTTLS on port 995?
Annie
Fixes: 585
@Annie you can't use STARTTLS for POP on port 995, its only used for the outgoing server. You should use SSL/TLS there's a subtle difference...
@Annie
It's possible to test your connection using the instructions here Diagnosing email server connectivity issues the guide
You'll be looking to use these settings
  • IMAP: imap.plus.net port: 993 TLS/SSL
  • POP3: mail.plus.net port: 995 TLS/SSL
  • SMTP: relay.plus.net port: 587 STARTTLS
Hope this helps.
@MisterW got there first.
Annie
@Dan_the_Van and @MisterW
Thank you both. I've changed to using SSL/TLS and all is working now. The instructions on that web page (https://www.plus.net/help/email-guides/how-to-set-up-plusnet-email/) didn't make it all that clear.
Annie
Fixes: 585
The instructions on that web page didn't make it all that clear.
I'd have to admit that, they don't specify the encryption at all for the incoming server. Having said that, I thought most email clients would default to SSL/TLS using port 995 when POP is selected.
Annie
It's a while since I set up the email accounts in Thunderbird so I don't remember what it defaulted to.I had previously been using port 110 but thought it better to add some security which is where I went wrong. Ha ha.
Annie
