Alias what's it mean and why you use it instead of redirect?
FIXED- Subscribe to RSS Feed
- Re: Alias what's it mean and why you use it instea...
25-09-2019 10:46 AM - edited 25-09-2019 10:47 AM
I've created an email address and redirected the mail to my main PlusNet account, but rather than the TYPE being 'redirect' it is alias.
What difference does it make being an 'alias' type, what's its purpose?
Fixed! Go to the fix.
Re: Alias what's it mean and why you use it instead of redirect?
25-09-2019 10:55 AM
25-09-2019 11:47 AM - edited 25-09-2019 11:51 AM
Thanks for the reply.
When you say local you mean another plusnet account and redirect can forward to an email account with any other provider?
Aliases doesn't mean being able to send an email with the address of the sender concealed?
25-09-2019 1:35 PM
Thanks for getting in touch @christmas
Effectively an alias would redirect to a mailbox you've already created under your account
A redirect would go to whatever address you specify
25-09-2019 1:50 PM
Unfortunately (for some) aliases do not allow the sender name to be concealed.
25-09-2019 2:02 PM
26-09-2019 10:11 AM
Hi @christmas
Think of alias as another name for the same thing. Say you have a mail address of Christmas@ then the following might be alternative (alias) names for the same mailbox...
- Xmas
- Chrimbo
- Noel
- Yuletide
- Yule
- Santa
Some email clients allow the use of alternative identities on a given mailbox. The round cube webmail client certainly allows that. Outlook 2016 does as well, but it will identify the email as (for example) From Christmas@ sent on behalf of Santa@
30-09-2019 8:31 AM
For example with round cube you can create no end of aliases (identities) for sending (that client really does send as alias@) without needing to configure the alias name on the mailbox using mail manager. This can be very useful when used with the catchall mailbox. It allows you to use different email addresses with different parties (especially companies) - should one such party abuse / leak your email address, it becomes a simple task to redirect that alias to the black hole. It is a highly effective method of planning to manage spam and abuse of your email service.
