Additional mailbox wont work iphone 6
FIXED- Subscribe to RSS Feed
- Re: Additional mailbox wont work iphone 6
30-06-2017 11:40 AM
Hi all,
I'm a new user and in the process of setting up.
I've created a new mail box which works fine on webmail both receiving and sending mail.
My supplied email name@username works fine on the iphone and web mail too.
I've set up another mailbox with a full stop - name.name@username - the email I received shows the username to be username+email but despite a number of attempts in wont receive emails.
just for added info I've not yet got the broadband set up so does that make a difference? As you can appreciate i want to use new email addresses before my current supplier switched my existing ones off.
Fixed! Go to the fix.
30-06-2017 12:31 PM
Welcome to Plusnet
I've just set up a new mailbox including a full stop to check the process and it's working OK.
Thank you for mentioning your broadband service is yet to go live. That does have an implication, but only in so far as you will not be able to use the Plusnet SMTP relays from an email client on your computer until it does *. However using webmail is OK.
If you set up a new mailbox called one.two the address for sending mail to it is
one.two@username.plus.com
However to collect mail the username you enter (eg into webmail) is
username+one.two
with the password you created for the one.two mailbox
When I entered that in webmail I was asked to create an identity. I entered One Two as my display name but had to overwrite the pre-completed email address completely with
I hope this helps
* For sending using an email client you will have to continue using your current ISP's SMTP server until your Plusnet broadband is live.
30-06-2017 3:53 PM
Nothing more to add to Spraxyt's post, he's covered everything I'd mention.
02-07-2017 3:05 PM
Thanks both for the welcome and the response. What you have described is exactly as I understand it. The one.two@username.plus.com works fine on webmail but not on my iphone 6. It says the imap server is not responding. However the first mail box which is the one assigned by plusnet works just fine on the iphone.
02-07-2017 3:32 PM
Check that the server name is correct - imap.plus.net with no trailing spaces.
02-07-2017 3:55 PM
Thanks was showing mail.plus.net and despite changing setting to imap it wouldn't save. Deleted and recreated seems to work now.
02-07-2017 4:56 PM
Moderator's note by Mike (Mav): I have changed the fix to @Townman as per message #5.
Forum Moderator and Customer
