Trial router
Trial router
Is Matt Taylor in today -
I sent him an email in reply to the instructions re the test router.
I have look after two accounts - one home one and one in an office - so want to know which one the router was set up for.
mal
James
Re: Trial router
Hi Mal,
It's the one for #11.
Re: Trial router
Ta james
Re: Trial router
OK - I've read all the messages here - and am ready to go ahead, but as I'm home in the morning I will do it when more PN staff are in in case of problems or they want to watch logs.
Any current issues I need to watch ?
Fixes: 46
Re: Trial router
If you want to use wireless check the WPA key on the router configuration page. You might find the value differs from what it says on the label.
David
Re: Trial router
Thanks Spraxyt ,
So far no issues - it did connected straight away about 5 minutes ago. Very good.
No laptop at home at the moment to check wifi
Re: Trial router
Yes indeed - the WiFi encrypion key is different from the label that came with the router.
Fixes: 8
Re: Trial router
I never successfully completed the Password change - though I now Spraxyt did.  Some system re-think on how to detect Router 0n-line being designed?  See my other thread.
Maurice
Fixes: 46
Re: Trial router
Perhaps changing password works only on F9. That would be a first. Crazy
David
