Success on 2nd attempt
paulap
After a reset all is now working but still had to enter username and password.  The userguide suggests the username will be username@plusdsl.net when it was actually just username.
Only problem I have now is that my VPN connection terminates after 10 minutes which didnt happen on my other router.  I will try a VPN upgrade to see if this resolves the problem.
1 REPLY
Plusnet Staff
Plusnet Staff
Fixes: 159
Re: Success on 2nd attempt
Thanks for letting us know.
That sounds like you were hitting the 'walled garden', it's basically another aspect of the router setup trial we are testing. If you haven't already, can you fill in the survey at http://www.zoomerang.com/Survey/?p=WEB229CJHCWTV9
 Chris Parr
 Plusnet Staff
