Easy setup firmware
Easy setup firmware
Hi all,
The utility to upload the firmware from http://bobpullen.net/585v7_setup.zip
The original firmware that is installed currently is at http://bobpullen.net/Firmware 7447v3.zip
The updated 585v7 firmware is at http://www.binarybob.plus.com/Plusnet Branded TG585v7 R7447 DEMO.bin
The updated 5x6v6 firmware is at http://www.binarybob.plus.com/Plusnet Branded ST5x6v6 R7447 DEMO.bin
Any further versions and we'll update this post for you.
silverfox0786
Re: Easy setup firmware
Just to make you aware when i upgraded the firmware it failed the upgrade but when lookikng at the router page it shows as the upgrade has been applied. very confusing?
Plusnet Staff
Plusnet Staff
Fixes: 159
That is strange. It may be because your PC was allocated a different IP from the router once the firmware upgrade was applied so it couldn't detect the device connected straightaway.
 Chris Parr
 Plusnet Staff
