Documentation
Documentation
Can i make a plea for a advanced user manual - for those of us that understand such things,
including how to update firmware etc etc.
and make it easily found from the help pages
Plusnet Staff
Plusnet Staff
Re: Documentation
Mal,  we're not going to support firmware updates in the CSC so no, we won't be publishing any user guides to firmware.  This does sound like the ideal sort of thing to go into the beta Support Library though.
[Moderator's note by Adie (Adiewoo):  Full quote of preceding post removed, as per Forum Rules  some people... ]]
Plusnet Staff
Plusnet Staff
Re: Documentation
BTW we're keen to complete the feedback from people on the trial as soon as possible.  If YOU are on the trial and haven't given us your feedback yet please do try the tests and return your feedback to us as soon as possible.  Thanks.
Re: Documentation
I would give feedback if I could get the router to connect !
adie:quote
Re: Documentation
some people...
are just over zealous  Wink
Fixes: 9
Re: Documentation
I will get around to the reflash and retest as soon as I can, but after a week of limited progress on the problem - you've just hit some bad timing on my availability Cry
I'll get around to it soon.
Maurice
