Change password testing
Plusnet Staff
Plusnet Staff
Fixes: 159
Hi all,
For those of you who have been helping with the testing so far, thank you. It's much appreciated.
We have another item we'd like to test, that is the change password functionality.
Once you've set up your router and left it for around an hour then it should be ready to try changing the password.
To do this:
1. Go to https://portal.plus.net/my.html?action=change_password&s=0 and log in
2. Change your password
3. Wait 5 minutes and then reboot your router
4. Did your router reconnect automatically?
5. If you want you can change your password back to what it was previously.
If you can test this and leave feedback in here I'll pick it up, thanks.
 Chris Parr
 Plusnet Staff
Re: Change password testing
That's already para 14 of Matt's spec. ?
Worked fine for me
Plusnet Staff
Plusnet Staff
Fixes: 159
Yep, it's already in the list but we've not had much specific feedback on it so I started this thread Cheesy
 Chris Parr
 Plusnet Staff
Dave289
Tried it but got "Sorry couldn't find page you were looking for"
Embarrassed  Must be doing something wrong.... Undecided
Plusnet Staff
Plusnet Staff
Fixes: 159
There is another way to get to the change password page:
- Go to http://www.plus.net/
- Click 'Log In' (top right corner)
- Enter your username/password and login
- Click 'Account Details' (left hand menu)
- Click 'Change Password' (middle of the screen)
 Chris Parr
 Plusnet Staff
Dave289
Got it ~ changed password ~ no problems there....
Plusnet Staff
Plusnet Staff
Fixes: 159
Excellent, thanks.
 Chris Parr
 Plusnet Staff
Fixes: 46
I've changed my password 2 or 3 times since the website/router interface was built. The process worked OK on each occasion, including receiving the change confirmation email.
David
David
Fixes: 9
Apologies guys - good intentions but lack of spare time to do this second phase of testing so far.  I'm away for the weekend, but will get around to it on Sunday evening.
Maurice
