zone alarm help
zone alarm help
Trying to reinstall zone alarm after trying a harware firewall. I have decided to use zone alarm instead but it won't install.
I get a message saying zpy.dll not found try installing it again.
Any help appreciated.
zone alarm help
Done a bit of research on this on zonelabs website and apparently the version I am trying to install has found an original registration key or installed files from the previous installation. I'll try and contact zonelabs for more help.
The reason I stopped using the hardware firewall was because I couldn't port forward for games. I just don't know how to do it on my voyager 200 router.
Alecto
zone alarm help
After uninstalling zonealarm, run C Cleaner (free download, ), including the Sort out Issues option.
This ought to remove traces of the previous installation so the reinstall should work.
zone alarm help
Looks like thats it with ZA for my PC. will have to use the windows firewall version. it just wont install due to same problem.
